Curve Driven Pattern..
gahiggins
gahiggins
I am trying to pattern two features (a hex nut countersink and a thru hole) in a curved pattern on the top surface of a base curved extrusion. Number of instances should be 6 with equal spacing. Any help would be great.
Tom_Sturtevant
Hi gahiggins
I’ve attached a solution for this (Inventor 2022 version – hope you can open it!).
The basic approach is:
Create a sketch on the face with the hex hole
Project in one string of edges
Select the projected curves and create an offset to the center of the face
Constrain the offset curves to the projected center point of the through hole
Make the segment at the “far end” of the chain a construction curve
Sketch another line on top of that construction curve with its endpoint where you want your pattern to end
Exit sketch
Start the Rectangular Pattern command
Select the features you want patterned, select the sketch curve, set count = 6, use the “Curve Length” option for spacing, expand the dialog and pick the Direction 1 “Start” selector and select the projected center point of the through hole
Let me know if you have any trouble!
T.0.M.
Tom Sturtevant
Inventor Part Modeling Developer
Autodesk, Inc.
gahiggins
Hi Tom,
Would it be possible for you to post a short video showing this process..? I got as far as projecting and off-setting the contour of the curve.
I got lost when it came to constrain the offset curves to the projected center point of the through hole
Make the segment at the “far end” of the chain a construction curve.
Sketch another line on top of that construction curve with its endpoint where you want your pattern to end.
George Higgins
SharkDesign
Hopefully this makes sense to you
https://knowledge.autodesk.com/community/screencast/0a894fae-550d-4880-9622-9a84bf3b32e8
  Inventor Certified Professional
SharkDesign
Sorry I couldn't open your file because I'm on an older version.
Here's a demo that is closer to what you are doing.
https://knowledge.autodesk.com/community/screencast/eb306e60-a6af-45a3-b9a0-fb2210e1fdc1
gahiggins
Hello James,
Thank you for your video, this helped a great deal. I had to offset and dimension the contour of the curve, rendering the sketch fully defined, also the end points of the sketch were coincident with the center points of the thru hole and hex-counter also by dimension (which were separate features). From there, I was able to translate the seed geometry along the curve direction without rotation of the instances by choosing Compute > identical. Orientation > direction 1.
Thank you
George
