Curve driven pattern problem
TobiasZetterberg2067
Message 1 of 10
Hi, I'm modelling a helical shaped finned tube heater and ran into problem with "curve driven pattern".
I have a tube that is sweept along a helix and a finn that is also sweept along another helix. When I try to pattern the fin along the helical tube it goes all wrong. Inventor only suggests the fin to be patterned in a straight line perpendicular to the helix curve (see attached picture). I use the procedure with "Rectangular pattern" and use the helical curve in 3d-sketch as "direction 1", I also set the orientation of feature to "direction1". I tried to do this with features that was extruded or revolved and it works just fine but there seems to be a problem when the patterned feature is sweept. I also attached the .ipt if that can be to any help. /BR Tobias
Replies (9)
Message 2 of 10
CCarreiras
Hi!
Select where it beggins
CCarreiras
Message 3 of 10
Hi again and thanks for your reply!
That works for distributing the feature along helix but the orientation never aligns to the helix. If I use "orientation-identical" it don't rotates at all (as it should be) and if I use "orientation-direction1" it suggests to turn it 90 degrees but won't perform the operation (create rectangular pattern failed). Helical_feature2.png
Message 4 of 10
CStilesCARE
Not sure why it makes a difference, but instead of selecting the center curve line, select the one running along the inside of the tube. Seems to make it align better on my attempt.
Message 5 of 10
CCarreiras
I believe this is a bug for this particular part.
I guess is due the plane for the washer sweep is "parallel" to the helical curve, so the pattern direction is also parallel... how knows...
Anyway...
Since you probably will need a final assembly, the pattern will work in the assembly if using the Construction point pattern existent in the tube part... it's another option to consider.
CCarreiras
Message 6 of 10
Hi again! Both tips worked great. Thanks or all your help!
/BR Tobias
Message 7 of 10
And the result...
Message 8 of 10
CCarreiras
Nice!!
Put it here:
https://forums.autodesk.com/t5/inventor-forum/community-pictures-march-2023/m-p/11789852/highlight/f...
Also, if you have time, send the part to development to analysis and correct the issue.
CCarreiras
Message 9 of 10
CStilesCARE
Hey hey, that render looks nice! Would take my computer days to create, I'm sure lol.
Glad we were able to help!
Message 10 of 10
johnsonshiue
Hi! Another approach without using the patterning is to create a Twist Sweep (see attached image) as a surface body. Then thicken it to a solid body.
Many thanks!
Software Test Engineer
