On the other hand, thinking a little about the problem. I think you can't make a pattern in a sketch by taking a guide curve and maintaining the same separation.
If you need the same distance between the centers of each point, the method that I show you will not work for you (in the curve it will take the distance over the curve arc, not the linear distance). However, I would not recommend doing the pattern even if you could do it as you are proposing.
There is an alternative and very effective method, something more complex.
You must use equations and conditions.
The file I share is an old file, I did it a long time ago and it can surely be improved. It is an adaptable chain model.
Go to parameters and modify Z1, Z2 and "Desfase"
The interchanges and the diameters are changed and the chain is updated with the inserted parameters. Work with ilogic. It is an effective method because you don't have to edit anything in the sketch. When it comes to patterns, there may be problems that make it necessary to edit them when making changes
I hope this helps. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
