I've noticed recently that attempting to use Ctrl + C to copy the file location will sometimes not actually copy the text properly. I tested in another application and Ctrl+C worked fine there, so it's something wrong with that dialog box specifically. I can still right click and select copy to properly copy the selected text, and Ctrl+V still pastes copied text fine.
I suspect inventor thinks you're still selecting the components and copies them instead of the highlighted text, since attempting to paste will close the dialog box and paste a copy of the selected components. It appears to only occur if you select the components you want to copy before starting the Copy Component command.
I am on the most recent patch of inventor 2019.
