Cross section properties - Elastic and plastic section modulus
Hi!
Are there any ways to extract further cross section properties from custom profiles, than what you get from Inspect -> Region properties.
Specifically I'm interested in elastic section modulus (Wel [mm3]) and plastic section modulus (Wpl [mm3]) for checking linear buckling acc to Eurocode 3.
These are properties you get from tables for standard beams (IPE, HEB etc.) but we mostly make custom C-profile beams from sheet metal.
Using online calculators is a possibility, but you can only add flanges and web, with square corners. So this will simply be an approximation, and not accurate.
Calculating by hand is very time consuming, so extracting it from Inventor or Nastran would be handy.
