Creating workpoints from the vertex of a part[VBA]
Im trying to create an array of workpoints based on the vertex of a part. I want to create the workpoints with coordinates based on the part and not the coordinates from the main frame. I tried using this,
Dim wp As workpoint
Set wp = partDef.WorkPoints.AddFixed(ThisApplication.TransientGeometry.CreatePoint(0, 0, 1))
But, this just creates the point in space. Is there anyway to code it to accept the vertex from the user and create it based on that?
Xun.Zhang
Firstly, you have to get the property of that point with VBA based on a projection of 2D sketch, and than you can create workpoint based on that point.
Here is a sample for your reference.
Dim oApp As Inventor.Application
Set oApp = ThisApplication
Dim oPartDoc As PartDocument
Set oPartDoc = oApp.Documents.Add(kPartDocumentObject, _
   oApp.GetTemplateFile(kPartDocumentObject))
Dim oSketch As PlanarSketch
Set oSketch = oPartDoc.ComponentDefinition.Sketches.Add _
  (oPartDoc.ComponentDefinition.WorkPlanes.Item(3))
Dim oTG As TransientGeometry
Set oTG = oApp.TransientGeometry
Dim oSkPnts As SketchPoints
Set oSkPnts = oSketch.SketchPoints
Call oSkPnts.Add(oTG.CreatePoint2d(10, 20), False)
Xun
dgreatice
please provide screenshot or attachments to help another.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Awesome I think this should work. Thanks a lot!!
