Creating Surface from Excel (points generated in Matlab)
westlam
Autodesk Autodesk
westlam
Hi All,
I have a specific request from a customer who is switching to Inventor from Solid Edge. They would like to create a complex surface from 5000 points, which are generated by Matlab then go into the form of Excel. Is there a way to do this in Inventor or Fusion?
Oringinal comment from customer:
"We use the SolidEdge ‘bluesurf' command to produce a complex surface from 5000 points generated by Matlab, placed in an excel file and imported into SolidEdge."
Has anyone come across this command in SolidEdge?
I've had a look on the forum, and this is the closest I could find to my issue:
https://forums.autodesk.com/t5/inventor-forum/spline-a-surface-from-points-imported-from-excel/m-p/4...
So I'm assuming it's as simple as opening up a 3D sketch and importing points, but as there are 5000 I'm wondering if this will be able to compute. I don't have the Excel data but have requested it. The bit I struggle to get my head around (personally) is how does it compute which point is connected to which point?
Any help very much appreciated as always.
admaiora
Hi West,
that's the path
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
I believe that there are no issues for 5000 point. (Not sure)
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
swalton
I don't think Inventor knows how to convert a point cloud to a surface.  See @SteveMDennis's comment on this thread: https://forums.autodesk.com/t5/inventor-forum/surface-through-work-points/td-p/6650645
Civil3d can do it.  See: https://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2016/...
I have not used Resurf, but it looks helpful: http://www.resurf3d.com/Pointcloud2Nurbs.htm  A $150 purchase is much less than Civil3d....
Steve Walton
Inventor 2025
Vault Professional 2025
westlam
Hi both,
Thanks for your reply. It's the create surface from points that appear to be missing in Inventor. I think Alias has it as well so it's possible in Autodesk technology, just not Inventor (based on the fact that inventor is primarily a solid modeler i would presume??).
Thank you all for your help and links.
Wonder if it'll be put into Fusion?
Mike
