Creating spiral path
I need to create a large pattern of holes, where the holes are spaced a couple millimeters apart and located on a spiral path starting on the outside of a disk and terminating at the center.
Can anyone tell me how such a spiral path is create in Inventor?
Thanks ahead.
JDMather
Attach the *.ipt attempt you have made here.
I would do as a Coil surface feature and Curve Driven Pattern.
You have done what I would like.  Can you tell me how you created the 2D spiral?  It seems to me that Coil is for creating 3D spirals.
mflayler
There is a Spiral Option in the Coil command.  Cerate your coil the way you want and then use the Rectangular Pattern command with the Curve Driven option.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
JDMather
See post #8 in this thread on a Helical example
http://forums.autodesk.com/t5/inventor-general-discussion/skillsusa-document-now-on-screencast/m-p/5...
but instead of Helix - select the Spiral option of Coil as shown in Mark's image above.
