Lately, everytime I go to create a PDF from an IDW, I get the following error (please see attachment) even though all views are up-to-date?
Solved by karthur1. Go to Solution.
Do you see the raster view icon on any of the drawing views? Maybe its one of the sub views buried under a main view.
Try right clicking in an open area of the drawing and then select "Make all view Precise". Try to PDF again, do you still get the message?
Kirk
I think this was a new feature in 2015. It is supposed to update the idw in the background. If you wait long enough, it will eventually go precise. How long??? not sure about that.
You can get it update the view when you place it. Look under Tools > app options, Drawing tab. Uncheck the "Enable background updates". I think its checked by default. I have mine unchecked.
Thank you for giving tutorial on creating PDF, I also can't understand French, English tutorial will be better.
Best regards.
