Creating Multiple Emboss Lengths From One Sketch
I am trying to make a part in which there is a embossed Xbox logo.  I am trying to make the center X embossed a short amount and the rest surrounding circle a longer amount.  Is there anyway to do this from one sketch?
salariua
you can revolve a surface and then extrude, up to that surface. post your attempt if you can't figure it out.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
mcgyvr
In general yes..
Do your sketch..
extrude once on one profile
the right click on the sketch in the model browser and pick "share sketch"
then extrude the other profile again..
Thank you for the help!  The solution worked fine.
