Creating holes with rectangular array
CalmWind
CalmWind
Someone please help me with the array problem.
I have created two separate holes at either end of my folded metal sheet.  Now, I need to places as many holes between them as possible with a length of approximately 100 mm between two adjacent holes.  I tried the rectangular array, but the arrow kept pointing at out of plane direction.  I think I am doing something wrong.
Can someone point me to the right direction?  Yes, pun intended.  Thanks.  Smiley Wink
A tutorial video would help a lot too.  Thanks.
graemev
Select an edge or axis for the direction of the array, not the face. After that, it's a simple matter to calculate the quantity of holes via length and spacing parameters. (Use "floor" or "ceiling" as necessary in your equation.)
admaiora
You can improve it using parameters too
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
CalmWind
Thanks for the help Admaiora.  It worked.
Another quick question please.  If I want to delete the 2nd or 3rd hole or whichever hole I desire.  How would I go about doing so?
I tried selecting it and hit delete, but it does not work.
Thanks in advance.
maulik_patel
Hi!
Occurrences created by pattern cannot be deleted. However, you can suppress it( RMB on it/Select 'Suppress').
Maulik Patel
SQA Engineer
dan_szymanski
Hi @CalmWind,
You can suppress occurrences (generated from the pattern) from within your Browser per your design need.
  • Expand the Rectangular Pattern feature from within the browser to expose all the occurrence nodes
  • Right click on a Occurrence (it will cross-highlight within the graphics area so you can see the selected feature)
  • Select Suppress
Hope this helps some.
Dan Szymanski
Sr. Product Manager
Autodesk, Inc.
