flathead.ipt has problems with sketch/extrusion 3
I see pink geometry that needs to be fixed..
Its causing problems rebuilding the part properly..
Hence anything after that can get "wonky" ![Smiley Very Happy Smiley Very Happy](/i/smilies/16x16_smiley-very-happy.png)
Correct that then proceed and see if the issue clears up..
And and just about all your sketches are not fully constrained..
Don't exit a sketch until it says "fully constrained" in the bottom right corner..
And I'd suggest turning on "Autoproject part origin on sketch create" from tools..application options..sketch tab and center all first sketches on the origin point..
These last 2 things are considered "good form" and unconstrained sketches,etc.. can cause problems further down the road..
dang.. JD and Sam beat me to the punch.. JD's punch was a bit harder though.. ![Smiley Very Happy Smiley Very Happy](/i/smilies/16x16_smiley-very-happy.png)
