Creating a plane through an axis
Message 1 of 10
Hi
I can't see any way of achieving what I want.
Please see attached image below.
I've got a point cloud, and have set a plane (A) to represent the floor.
I now need to create plane B, perpendicular to plane A, to represent the inside wall of the enclosure.
I created points 1 and 2 on the surface of the wall, then created an axis through them.
I now need to create plane B by defining it as through the axis, normal to plane A.  The only command like this I can see is "Angle to Plane around Edge", but the axis isn't an "edge" so I can't use this command.
Is there a way to make the axis into an edge, or any alternative methods?
Many thanks
Replies (9)
Message 2 of 10
CCarreiras
Don't use filters.
Just do this:
  1. Create new plane,
  2. select plane A
  3. select axis.
This will create a angled plane between plane A rotating in the Axis. Give 90º.
CCarreiras
Message 3 of 10
SašoPrijatelj
After clicking Work Plane command just pick the axis and then the bottom plane. That's it if I got the question correct...
AutoDXF - automatic flat pattern creation and batch export to DXF for Inventor
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 4 of 10
Roelof.Feijen
I think this doesn't work because the axis is not parallel to the plane.
Try the following:
  2. Select plane A
  3. Select a point
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Message 5 of 10
Thanks.
I tried this, but if I select the axis I can't then select the plane, and vice versa.
I'm not aware that I'm using any filters.
Is this what you mean?  Choose Select Features?
Message 6 of 10
This is exactly what I want to do, but it won't let me....
Message 7 of 10
The axis is not parallel to the plane, but why should it need to be?  It should still be possible to define it using the axis and plane A regardless.
  2. Select plane A
  3. Select a point
just creates a plane through the point that is parallel to plane A...
Thanks for the help.
Message 8 of 10
SašoPrijatelj
Roelof is right. If the axis in not parallel to plane it wont work (but it should as far as I can see it).
Try this workaround instead:
Message 9 of 10
Thank you very much, I will try that.
Appreciated.
Message 10 of 10
Hi
Thank you for your suggestion.  For some reason when I click on the axis it won't project onto the plane, but instead I projected the two points onto the plane, and then created a new axis through those points.  This achieved the same thing.
Many thanks for taking the time to help.
