Creating a new folder in my Working Folder
Message 1 of 16
Can anybody tell me why Inventor is crashing when I create a new Windows folder in my Working Folder during the Save As dialog?
Replies (15)
Message 2 of 16
blair
I think it's because the folder doesn't exist within Inventors structure and outside of the Project File.
You could try creating the folder first using Windows Explorer and see if Inventor accepts it.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 16
Hi Blair,
Indeed, the folder is new, but under the parent project folder and therefore inside the Project File. When I create the folder in Windows Explorer, there won't be a problem. Problem is that the need of the folder arises during the Save As dialog. Using the 'New Folder' button in this dialog would be the most logical way.
Regards, Jan
Message 4 of 16
Rob67ert
Hallo Jan,
I do it the same way, never had any problem.
What OS do you use and Inventor version?
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Message 5 of 16
Hi Robert,
My OS is Win7Pro SP1 and my Inventor version is Inventor Professional 2017 (build 233, 2017.3 Update - Date Mon 10/31/2016)
Regards, Jan
Message 6 of 16
Rob67ert
Hi Jan,
Maybe the OS id doing something strange.
I work with Windows 10 and the same Inventor and Vault Basic 2017.0.1 (build 22.1.2.0) Without the problem you describe.
Robert
Message 7 of 16
Hi Robert,
It seems to be a local problem. My colleague with the same PC, OS and Inventor won't have the problem. Thanks for your response. Perhaps I should try another user on my PC.
Regards, Jan
Message 8 of 16
Mark.Lancaster
@Anonymous
If you have another user log onto your machine and it works..  That's an indication your Inventor Windows Profile is corrupt.  At that point run the Inventor Reset Utility.  This utility is installed on your machine or you can get it from the link in my signature (but you must come back to the forum to see my signature and link).
Mark Lancaster
Message 9 of 16
Hi Mark,
Thank you for your reply! The tool is on my machine. I'll try another user to find out the problem is my Inventor profile.
Message 10 of 16
blair
Just quickly create a new user account on that machine as see if that's causing your problems.
Delta Tau Chi ΔΤΧ
Message 11 of 16
Hello all,
I tried some options:
- another user on my machine: no problem
- me on my own machine with only a small part opened: no problem
- me on my own machine with a large assembly (1500 unique files, 12000 instances) opened: problem appears and Inventor crashes
Regards, Jan
Message 12 of 16
blair
Sounds like a bad User Profile. If you have an IT department there, get them to look at repairing your profile.
I've attached a guide on the procedure.
Delta Tau Chi ΔΤΧ
Message 13 of 16
mcgyvr
@Anonymous wrote:
Hello all,
Regards, Jan
And did you try the "Inventor Reset Utility"? If so did that help?
Message 14 of 16
Hi all,
Thanks all for helping so prompt! I just tried with the Inventor Reset Utily, but it doesn't help. I'll try the option to repair my windows profile, unfortunately it has so a large effect on the daily way of working 😞
Message 15 of 16
Jon.Dean
Hi Jan,
Good luck with the repairing of your Windows profile.
Please keep us informed of your progress.
Cheers
Jon.
Jon Dean
Message 16 of 16
This morning I removed my Windows User Profile by the standard Windows procedure (System, Advanced Settings, User Profiles, etc.). I checked the register for the related keys and they were erased. Till now the problem is solved under the same conditions as it appears before!
Unfortunately I have/had to do all user settings for all my software. It cost a lot of time.
Regards, Jan
