05:58 AM
when placing a linear hole, can I dimension to a plane, for example I want to place a hole from the center of my part and there is a plane passing through the center, therefore I want to place the hole at a dimension of zero from the plane. Usually on a sketch I can just project the plane. Also I know I could create a sketch prior to making the hole but I was just wanting to place via a dimension while creating the hole and not using a sketcth or a prior created point.
