Creating a corner chamfer
SHamrick
SHamrick
I am in the process of showing a co-worker how to use Inventor who is switching over from Creo. In Creo you can do a corner chamfer, giving either the three dimensions or clicking and dragging from the corner. You can find a short video here: https://www.youtube.com/watch?v=6UVFrgA4Nos
Is there a way to create something like that in Inventor?
All of the corner chamfers need to be at the 6 3/4 x 5 1/2 x 1 3/16. The material thickness will remain the same but the overall sizes of the pieces will change.
The steps I took were drawing an angled work plane, drawing a sketch on the plane and doing a extruded cut. The problem is I am not getting the desired dimensions I need. The 1st view shows my steps, the other views show what it looks like pulled in from Creo to Inventor and the desired dimensions.
Please advise and thank-you in advance!
Binga
There is no tool to do this directly (I guess).
But you can do this:
1 - Create 3 points to drive your cut (I have created these points with sketchs)
2 - Create a work plane using te three points
3 - Split the solid
Check the attached file.
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
JDMather
Attach your *.ipt attempt here if you can't figure it out.
PaulMunford
If the Chamfer is equal on all sides, you can use the standard Chamfer tool and then delete the faces you don't need with the 'Heal Edges' option.
Customer Adoption Specialist: Autodesk Informed Design
Help | Learn | Forum | Blog | Ideas | Sample content | Linkedin
SHamrick
Thanks for input, was looking to create chamfer without it being all equal sizes.
zakazai
But is it possible something like this?
JDMather
Can you attach your *.ipt file here?
Is this a real part - or is it an academic exercise?
