Creating a Continuous/Flexible Screw Mount in Inventor
mohammad_sohaib
mohammad_sohaib
I have a T-shaped adapter part in Inventor with two circular holes on one side. I need to modify this design to create a continuous/flexible screw mount that would allow for adjustable positioning between these two hole positions.
Currently, the part has two fixed circular holes, but I'd like to:
  1. Create a slot connecting the two holes
The goal is to allow for more mounting flexibility and adjustability when the part is installed.
Has anyone done something similar? What would be the best approach in Inventor to create this type of flexible mounting solution? I'm considering both the design functionality and the manufacturing implications.
Any step-by-step guidance or examples would be greatly appreciated!
JDMather
@mohammad_sohaib
Can you Attach your file here?
Have you used Sketch Slot tool before?
mohammad_sohaib
This is the .ipt file for reference.
I have not used this tool yet.
kacper.suchomski
Kacper Suchomski
johnsonshiue
Hi! On top of what Kacper already mentioned, here is another solution by using Solid Sweep. Please take a look.
Many thanks!
Software Test Engineer
kacper.suchomski
Following Johnson's lead, you can also use the classic Extrude from a 2D sketch.
Kacper Suchomski
