Creating 2 part Die for Plastic Jetting
Hello, I need help with creating 2 part die for plastic jetting. Idealy upper die as one file, bottom as another one.
I will simulate creation of die with 3axis milling, so It must be manufacturable by that.
I use Inventor 2016 Professional.
I´m attaching a simplified picture of how it should look like. I was trying to make rectangle and then extrude it "up to next" but thats not working due to the holes and stuff. I´m just learning to work in Inventor and Can´t figure this out.
Can you help me ?
Thank you
mcgyvr
Inventor pro has mold/tooling for designing injection molds..
If you don't want/don't know how to use that you can use derive to create a simple clam shell mold..
see here
http://www.widom-assoc.com/derived_parts2.pdf
Here is some info on mold/tooling design
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
JDMather
You are missing draft angle on a lot of faces and missing dimensions?
Also, I think you might need to reconsider some of the geometry to get clean parting edges.
I have no idea what you mean JDMather...
Also mcgyvr that mold tool was somewhat helpful but it´s too complicated.
There must be a easy way to make that form. Something like inverted intercepted extrude or something...
JDMather
Is something like this what you are trying to do (turn on your sound)?
This is exactly what I wanted.
THANK YOU !
mcgyvr
Guess you didn't see that I stated to use "Derive" in my post as well as using the mold tool module..
Now that JD has shown you just how easy the mold design module can be I assume you will use that now..
But "derive" functionality as shown in the PDF above is the way to do that without the mold module..
