Inventor Forum
Create Sheet Metal Formed Enclosure
5 REPLIES 5
dan6VKSR
398 Views, 5 Replies
Hello all and happy Friday!   I have never really used the sheet metal function of Inventor so my ability and knowledge is fairly limited.  I am attempting to create a formed enclosure frame that will be used as trim for a sandwich panel. The attached image is what my end goal will be.  Essentially fold all three sides, weld the mitered corners, slide the sandwich panel in and fold the final side to enclose the panel with the trim.  I was hoping someone can pass along a file that shows one corner and the workflow in how this can be achieved.
5 REPLIES 5
SBix26
in reply to: dan6VKSR
What version of Inventor are you using?  Nobody wants to put in the effort if you won't be able to open what they've created.
Sam B
Inventor Pro 2022.2.2 | Windows 10 Home 21H2
dan6VKSR
Inventor Pro 2022
SBix26
Here you go-- Inventor 2022 format.
Sam B
dan6VKSR
in reply to: SBix26
Thank you! I may pick your brain apart after reviewing the part if you don't mind.
SBix26
Sure, pick apart whatever of my brain is left!  But I won't guarantee a timely response.
Sam B
