I've been using Shared Views extensively. Our Marketing VP likes them. I'm finishing up a display project in Inventor. and the Shared views have suddenly failed to complete. I don't know how to diagnose the issue. I updated my Inventor yesterday, no change in behavior.
As the dialog runs and finishes, I get the message "An unknown error occurred, Please try sharing again. If this error please report it to Autodesk."
I hit the button to report it to Autodesk and it just - dumps me into the forums, it doesn't have me fill out a form like other problems do.
I've attached a version of the error message from Inventor and from Vault.
Any help please?
Signing out and back in with your Autodesk credentials may be a solution, according to another user who received the same type of error:
https://forums.autodesk.com/t5/inventor-forum/shared-views-service-error/m-p/8973456/highlight/true#...
On another similar thread, someone fixed their issue after changing the folder AppData in C:\Users\Public to 'visible'.
https://forums.autodesk.com/t5/inventor-forum/cannot-create-shared-view-inventor-2020/m-p/9371576/hi...
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
I looked at both those links. Shared View does work, even on a subassembly that goes into the top assembly. I think one of my beams levels has a corruption. In AutoCAD I'd run an Audit command.
Here is part that works. It is for a trade show.
Most of my levels in the affected assembly publish OK. This beam level kicks out an error. It does publish by itself.
I get this error generated though.
Can you try and publish a DWF file inside of Inventor from the assembly that can't publish a Shared View?
@whamlin
Are you able to share the dataset here with File\Save As\Pack and Go?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Hi Folks,
I am moving the thread to Inventor forum. This should not be Vault related. Based on the description, It is likely related the process of publishing the assembly at a particular level. There is some sort of corruption. Try doing Rebuild All (Manage -> Rebuild All) and then publish. Does it work better?
Many thanks!
Thanks Irvin!,
That did work. Also, after I did that, The Shared View worked for the project. It's funny as this was the only project I could not get to publish.
Thank you all for your comments and suggestions.
@johnsonshiue , - thanks for moving this to the correct Forum. 🙂
Shared View:
@whamlin Very nice!
Chris Benner
