Create New File Default Location
EagleBee93
Message 1 of 26
EagleBee93
Picture attached. Everytime I go to create a new file since getting Inventor 2024, it defaults to the folder en-US with Inventor's default templates. I'd like it to default to the highlighted folder "Weber Group" with my personalized templates. How do I do this?
Accepted solutions (4)
Replies (25)
Message 21 of 26
EagleBee93
Any idea as to why an imported CAD file keeps defaulting to a "generic" material and "shaded" appearance when there is no such part file in the templates folder at all? I've checked the default template folder path, and all of the part files in the template folder to make sure everything is set to "stainless" and "shaded with edges" but alas... it's not working.
Message 22 of 26
EagleBee93
I keep having this problem for some reason 🤷‍♂️
Message 23 of 26
johnsonshiue
Hi! If there are no Standard.ipt or Standard.iam file in the active template folder, no templates (system defaults) will be used. The styles are all based on internal default. I suggest you set up Standard.ipt and Standard.iam template files in the template folder.
Many thanks!
Software Test Engineer
Message 24 of 26
EagleBee93
So does it have to be the original Standard.ipt file that came with the install? Or can I just rename my part file to "Standard.ipt"
Message 25 of 26
SBix26
You can rename your template(s).
Sam B
Inventor Pro 2024.1.1 | Windows 10 Home 22H2
Message 26 of 26
EagleBee93
Yeah I tried that yesterday and now it's working the way I want it to. Thanks everyone!
