Hey,
I am currently working on printing my own Fingerboard using layers of filament, which I plan to press with a mold. I have read couple of posts regarding the generation of molds by creating the positive fingerboard first and use the mold tool afterwards. This way works fine, but the mold has a weird way of cutting the two parts, since Inventor assumes that I want to build a "pouring" mold, while instead I want to build a press mold. In the attached picture of the finished mold you can see, that the mold parts are not cutted "following" the shape of the fingerboard, but instead in a more horizontal way.
In the second picture (fbmold_extrusionproblem.png) I tried to place a working layer beneath the fingerboard and then do an extrusion from the working surface to the lower layer of the fingerboard. Sadly, the function I tried ("to the next" in english?) shows the error message that no volume could be created. Is there maybe a function in Inventor to get an extrusion off an arbitrary surface of a part? That would be really easy since I could just extrude each part of the mold off the top and bottom layer of the fingerboard.
I hope you can help me out on these problems.
