create forged part from final part
I want to create the original forged part from finised machined part like these pics
is there a way to do it in autodesk inventor 2015 professional? if there isn't is there an other program with which i can do it.
Thank you in advance
Nick
JDMather
You could do a Derived Component and work your way backwards, but forged parts differ significantly from blank to finished part.
Do you have physical example parts along the process?
I don't think you will find an Easy Button solution.
I am a student of mechanical engineering in Technological institute of Pireus Greece and i want it for my graduation Thesis. The supervising professor asked me if i could do something like the pictures above so he can determine the dissertation topic
mcgyvr
Inventor can do it..
Typically one would start with modeling the forged part then deriving that into a new part and adding new features (extruded cuts/holes) to simulate the post forging machining that is performed on the part..
Using the derived part functionality if you make a change to the as forged part those changes will also occur on the finished part file (hopefully without issue)
You could also just model each one up as its own part..
