Create flat pattern not working
Message 1 of 13
I converted a 3D part file to sheet metal. I then tried to create a flat pattern from the new sheet metal part. Having no luck I checked all sheet metal parameters and even went back and checked the original sketches to ensure there are no glitches with the original part. After many attempts I still can't get a flat pattern to develop from the sheet metal part. (attached)
I've already generated some other flat patterns in the same manner described from other parts. I've tried this part at least ten times with different scenarios ( radius changes, sheet metal parameters) but still can't make it work.
Bob W
Inventor PRO 2017
All recent updates & Service Packs
Replies (12)
Message 2 of 13
JDMather
What is the modeled Thickness of your part?
(Hint: It can't be manufactured.)
(Hint #2: It isn't uniform thickness.)
@Anonymous wrote:
... and even went back and checked the original sketches......
(Hint #3:  Forget you ever saw the Autodimension tool.)
Message 3 of 13
The thickness is .06 inches or 16 ga.
Message 4 of 13
JDMather
Nope.  Check again.
You have several dimensions that are not measurable and therefore not manufacturable.
Message 5 of 13
blair
I generally work the other way and use the extrude to surface, thicken and convert. This provides a uniform thickness.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 6 of 13
JDMather
Hint #4.  Your very first dimension is incorrect.
Not a good way to start.
Message 7 of 13
blair
That will do it right there. Smiley Surprised
Delta Tau Chi ΔΤΧ
Message 8 of 13
Gentlemen,
Sorry for the late reply.....internet issues on this end!
Thanks for your input on this. I developed tunnel vision and could not find my error. I must have used the distance tool 50 times checking the thickness not even realizing I should increase the decimal places. I'll have to pay more attention to my sketch skills and settings in the future.
Thanks again!
Bob W
Message 9 of 13
Curtis_Waguespack
@Anonymous wrote:
...I must have used the distance tool 50 times checking the thickness not even realizing I should increase the decimal places.
Hi Mr_iso,
See there was some improvement for this just recently.
I hope this helps.
Curtis
Brand new for Inventor 2017 R2
Improvements to Measure Command Precision
Visual enhancement: A check mark now displays next to the default Measure Distance, Angle, Loop, and Area Precision value when you access the list for the first time in a file. Previously the check mark only displayed after you made a selection.
Inventor 2017: The checked measure precision value now persists across sessions in all files. Select a different measure precision value to change the default measure precision value. Previously when you changed the Precision value in existing files, the change was not maintained after saving, closing, and reopening the file.
Important: When you create a new template file in any new version of Inventor (for example Inventor 2017 R2, R3, 2018, and onward) the default measure precision value must be set in both Document Settings Units tab Modeling Dimension Display fields and in the Measure Precision value dialog box.
Message 10 of 13
You have to create the flat pattern in the part modeling environment first. Make sure it can be created there, then go back to drawing file and try again!
Message 11 of 13
georagette.tan
Hi, I have the same issue with my part. Appreciate the help. Thanks!
Message 12 of 13
georagette.tan
same issue here. need help!
Message 13 of 13
johnsonshiue
Hi George,
Please share the files. I would like to understand the flat pattern error more clearly.
Many thanks!
Software Test Engineer
