create an animation within an assembly
mike_austvoldXF37J
mike_austvoldXF37J
hello, I am using inventor 2024 and I want to create an animated assembly using shoulder bolt following a slot that isn't straight.  Screenshot 2024-08-21 141143.png
kacper.suchomski
Hi
You can use the rendering environment in an assembly file or create a new presentation file.
Kacper Suchomski
johnsonshiue
Hi! This seemingly simple movement is not that simple to animate in Inventor. Please share the files here. The forum experts can help take a closer look. Is this a school assignment? If yes, please do your homework yourself or discuss it with your TA and teammates.
Many thanks!
Software Test Engineer
mike_austvoldXF37J
no I'm not a student and finding out this is harder than I thought. Ant help would be great. thanks
johnsonshiue
Hi Mike,
Here is what you need to do. I believe you will need to use Transitional constraints in the assembly. First, try creating zero-offset surfaces from the slot faces (Thicken/Offset). Then create two Transitional constraints between the bolt and the slot offset surface. After that, add a Flush or Mate constraint between the bolt and the side vertical face of the plate. Lastly, drive the Flush or Mate constraint.
mike_austvoldXF37J
thank you I will give that a try
mike_austvoldXF37J
THAT WORKED THANKS FOR THE HELP
