Create a solid volume out of stl file (mesh)
I downloaded a file from Thiniverse and want to adapt it to my needs. When I import the stl file it shows up as a mesh feature, and I am able to convert it into a surface body using "mesh enabler". But I can't figure out a way to convert it directly into a solid body or through the surface body into solid. The surface body is just one surface, otherwise I'd try to use function to combine two surfaces.
It'd be great if anyone has a solution.
