Create a part in assembly with adaptive geometry
danijel.radenkovic
Message 1 of 8
danijel.radenkovic
Hello to all,
I have created a new part with referenced geometry to another part but I forgot the way how I did it sometimes in the past. Last few years I am working with multibody parts so I have forgot old way through assembly. Now, I am trying to do it again on the old way (through assembly), but as you can see on the attached video, geometry of the new part is not updated. Somehow projected lines are fixed-not adaptive. Where I am doing something wrong?
Any help is very appreciated.
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
Replies (7)
Message 2 of 8
mdavis22569
Look at 40 seconds into your video....
You make a rectangle.. that would need to be based on the adaptive. Also if you look at the line it's full of lock symbols
Mike Davis
Message 3 of 8
danijel.radenkovic
Yes, I saw those fixed constraints but they are added automatically. Do I need to remove them manually and create a new collinear (or coincident) constraints?
Message 4 of 8
Fouad-l
Hi.
Please tray to continue drawing the rectangle from the projected lines instead of using the rectangle command.
When you draw the rectangle, there is a line that overlies the adaptive line. I think the revolution operation uses the line of the new rectangle instead of the adaptive one.
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
Message 5 of 8
mdavis22569
working on a solution using adaptive (which I don't use often, and avoid at all cost)
Mike Davis
Message 6 of 8
danijel.radenkovic
@Fouad-l wrote:
Hi.
But I don't see the reason why it doesn't work? It has to be ok cause line of the rectangle is attached on the adaptive (projected) line and it is normal that rectangle's line ALWAYS move when adaptive line is moved. Am I right?
By the way, I have tried what you advised but attached geometry is still fixed. Actually, fixed constraints are added automatically and immediately after projecting the edges.
Message 7 of 8
johnsonshiue
Hi Danijel,
The edges you were trying to project are silhouette edges. These edges are not actual edges. The geometry and topology of such edges can change based on the view direction and the sketch plane direction. Inventor never supports adaptivity on silhouette edges. You might have selected an actual edge to project before.
Many thanks!
Software Test Engineer
Message 8 of 8
danijel.radenkovic
@johnsonshiue wrote:
Hi Danijel,
Many thanks!
Hello, Sir,
Thank you very much for the reply. So, I have used split face feature to get some visible edges. It works!
Perfect! Thank you very much!
Danijel
