Hello everyone.
To begin, I am not very savvy in the iLogic department so please bare with me. I have created an iLogic form that I use to create Certification drawings with. Essentially, I punch in the information (tool number, project number, part name, capacity, etc.) into the form and it populates my text in the desired locations. Very convenient as I have multiple spots where the same information is required (tool number for example). I would like to take this a step further and have a drop down menu where I can select the bolt size (imperial) as well as the corresponding tap size. As it stands now, I have to look up the bolt/thread size and enter these values manually. Eventually I would also like to have it select the corresponding torque value based on a bolt suppliers recommended torque value.
Can someone point me in the right direction of how to achieve this? Perhaps even a simple iLogic code in which I can use to get started? If you require any additional information, please ask as I will be following this thread closely. I have attached an image of my current form so you can get an idea of what I am currently using. The "Diameter of Bolts" is where I would like to have the dropdown menu which will also populate the Torque value.
Thank you in advance.
