Hi
I would like to create custom material library folder and I am going the create custom materials inside this folder.
So I can select my customized materials from this folder.
Please any one, are you able to guide me ?
Kind Regards
Solved by Xun.Zhang. Go to Solution.
The attached document should help out. I'll see if I can find any other material in my library.
Hello @lkirit2000,
Here is the link help you to create a material library and put in any of folder you like.
A video for your reference as well.
While I appreciate the effort put into creating that video - I couldn't help but to think - what a perfect example of a gross misallocation of the funds available for the software development by Autodesk Inventor. The material library used to be relatively simple to handle and fairly logical in its structure. After the massive overhaul of the library (which no one ever asked for!) - it is now required an input of a ranking expert to explain - how to deal with it! Well done Autodesk!
Best Regards,
Igor.
