Countersunk Holes W/ Depth
Cadmanto
Mentor Mentor
Message 1 of 16
Cadmanto
Has anyone ever been able to use the Hole command to create the hole shown below?
I am not seeing an option to do this.
I know I can just create a sketch and revolve a cut feature, but when there are multiple holes in a block of wood, there is nothing convenient about that method. 🙁
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Replies (15)
Message 2 of 16
Cadmanto
I did figure out another method.  Create the counter bored hole then added a chamfer splitting the difference between the OD and ID.  This works and is not too painful.  It just would be a whole lot simpler if it was all under the hole command umbrella.
Inventor Pro 2020
Best Regards,
Scott McFadden
Message 3 of 16
Curtis_W
Hi Scott, this has been requested in the past, you better go vote... I think your vote is going to be the one to make it happen! 😉
https://forums.autodesk.com/t5/inventor-ideas/add-hole-type-counterbored-countersunk/idi-p/5497777
Message 4 of 16
Cadmanto
Hi Curtis,
As it stands, I already voted for it.  I guess this is what happens when an idea is in the pipe line for too long. 😴  Like 5 years for this one.  Should I add an English version of the idea to the station seeing this one is in Greek? 😁
I will add a comment with a link to this thread though.
Inventor Pro 2020
Best Regards,
Scott McFadden
Message 5 of 16
JDMather
I have a similar type need where I created a Punch tool, so that this works just like the Hole feature.
I simply:
Environments>Convert to Sheet Metal (even if it is absolutely nothing like a sheet metal part).
Create sketch with center point locations.
Place Punch (entering appropriate dimensions).
Environments>Convert to Standard Part.
Message 6 of 16
johnsonshiue
Hi Scott,
This requires two hole features. You can create a spotface hole and then add a C'sink hole.
Many thanks!
Software Test Engineer
Message 7 of 16
Curtis_W
@Cadmanto  (and anyone else that might be interested)
Here's a quick ilogic rule that will add a chamfer to a counterbore to do this... I didn't test it that much so it you might find issues with it, but it worked for my limited testing.
Just create an ilogic rule and add this code, then run the rule and select the counter bore hole
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Dim oFeature As Object
oFeature = ThisApplication.CommandManager.Pick(
  SelectionFilterEnum.kPartFeatureFilter,
  "Select Hole Features (press ESC to continue)")
If not TypeOf oFeature is HoleFeature Then
	MessageBox.Show("Hole feature not selected", "iLogic")
	Return 'exit rule
Dim oHole As HoleFeature
oHole = oDoc.ComponentDefinition.Features.HoleFeatures.Item(oFeature.name)
Dim oDiamParam As Parameter
Dim oHDiam As Double
oDiamParam = oHole.HoleDiameter
oHDiam = oDiamParam.Value
Dim CBoreDiameter As Parameter
Dim oDCBore As Double
CBoreDiameter = oHole.CBoreDiameter
oDCBore = CBoreDiameter.Value
Dim oEdgeCol As EdgeCollection
oEdgeCol = ThisApplication.TransientObjects.CreateEdgeCollection()
Dim oFace As Face
Dim oEdge As Edge
'Dim CurveEval As CurveEvaluator
Dim oDia As Double
For Each oFace In oHole.Faces
	If oFace.SurfaceType = SurfaceTypeEnum.kCylinderSurface Then
		oDia = oFace.Geometry.radius*2
		Logger.Info(oDia)
		Logger.Info(oHDiam)
		If oDia = oHDiam Then
			oEdgeCol.Add(oFace.Edges.Item(2))
	oChamferLength = oDCBore-oHDiam
	Try
		oDoc.ComponentDefinition.Features.ChamferFeatures.AddUsingDistanceAndAngle _
				(oEdgeCol, oFace, oChamferLength/2, 45 * PI/180)
	Catch
	End Try
Next
I hope this helps.
Curtis
Message 8 of 16
Cadmanto
Hi Johnson,
That is kind of what I am doing as per my second post in this thread.
Inventor Pro 2020
Best Regards,
Scott McFadden
Message 9 of 16
Cadmanto
JD,
That sounds like a lot of work.  No offense, buy I like my second suggestion better and even maybe @Curtis_W  iLogic rule (which I am going to try).
Inventor Pro 2020
Best Regards,
Scott McFadden
Message 10 of 16
Cadmanto
Hi @Curtis_W ,
I tried this rule and it sort of worked.  Meaning, I had a hole feature that encompassed 4 holes.  The rule only worked on one of the four holes.  When I selected another hole within the same hole feature, it did not convert.
Inventor Pro 2020
Best Regards,
Scott McFadden
Message 11 of 16
blandb
You could just offset a work plane to control the depth, then place the c'sink on that work plane, and utilize the extend start to generate the hole.
Counter drillCounter drill
Hope that helps.
Autodesk Certified Professional
Message 12 of 16
Curtis_W
@Cadmanto wrote:
Hi @Curtis_W ,
Ooops!, I didn't write it to look at a hole feature with multiple holes within it... I'll have a look later and see if that can be achieved too.
Message 13 of 16
doug.johnston
@johnsonshiue wrote:
Hi Scott,
Many thanks!
This is what I had to do yesterday.  The first time I've had to model this type of hole and was surprised it wasn't included in the Hole command.
It's not easy maintaining this level of insanity !!!!!
Message 14 of 16
NigelHay
 blandb, that works really well.
Message 15 of 16
Curtis_W
@Cadmanto
Hi Scott,
Here's a more robust version, it'll chamfer multiple holes within the same hole feature, and it'll allow you to select multiple hole features in a row.
I hope this helps.
Curtis
While True
	  "Select Counterbore Hole Features (press ESC to continue)")
		'if nothing then exit
		If IsNothing(oFeature) Then Exit While
	If Not TypeOf oFeature Is HoleFeature Then
		Continue While
	If Not oHole.HoleType = HoleTypeEnum.kCounterBoreHole Then
		MessageBox.Show("Hole feature is not a Counterbore", "iLogic")
		Continue While
	oHole.SetEndOfPart(False )
	'clean up existing chamfer (mostly for testing)
	Try
	sHole = oHole.Name & "_Chamfer"
	oDoc.ComponentDefinition.Features.ChamferFeatures.Item(sHole).delete
	Catch
	End Try
	'get the hole diameter
	'get the counter bore diameter
	'create a collection hold the edges
	Dim oFace As Face
	Dim oEdge As Edge
	Dim oDia As Double
	Dim oCir As Inventor.Circle
	'find the planer face in the hole
		If oFace.SurfaceType = SurfaceTypeEnum.kPlaneSurface Then
			For Each oEdge In oFace.Edges
				'find the edge in the face that is the same as the diameter
				If oEdge.CurveType = CurveTypeEnum.kCircleCurve Then
					If TypeOf oEdge.Geometry Is Inventor.Circle Then
						 oCircle = oEdge.Geometry
						 If oCircle.radius * 2 = oHDiam Then
							 'add the edge to the collection
							oEdgeCol.Add(oEdge)
			Next
	Next
	'calc the chamfer distance
	oChamferLength = oDCBore - oHDiam
	'create the chamfer feature
	Try
		oChamfer = oDoc.ComponentDefinition.Features.ChamferFeatures.AddUsingDistance _
				(oEdgeCol, oChamferLength / 2)
		oChamfer.name = oHole.Name & "_Chamfer"
	Catch
	End Try
	oDoc.ComponentDefinition.SetEndOfPartToTopOrBottom(False) ' Set to bottom
End While
Message 16 of 16
Cadmanto
@Curtis_W
Worked like a charm Curtis!!!  Thank you!!
Saved the rule for future use locally.
Inventor Pro 2020
Best Regards,
Scott McFadden
