Could not find file Thread.xlsx
alex_hiis6PJP6
alex_hiis6PJP6
Hello
Problem with accessing thread data after migrating to Inventor 2025.
In the screenshot I have shown that the thread.xlsx file is in the correct folder, but for some reason Inventor can't locate it.
Alexander_Chernikov
It is strange that file looks like MSExcel 97-2003
It should be *.xlsx with other size
Try to save it in new format.
For more info see:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Warning-Could-not-...
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
gbrisbinUZ9NP
I just experienced this same issue.
Autodesk has changed the following files for Inventor 2025 to use ".xlsx" files instead of ".xls" for the clearance.xls, thread.xls, bend table (mm).xls, and bend table (in).xls.
roloNCC
I opened the file and resaved it as .xlsx and it worked.
