Corner seam of two separate flanges (sheet metal)
boothdrafting
boothdrafting
How do I get the bottom flange to run flush up to the inside of the front flange? These are two separate flanges (different lengths). So I'm not able to access the corner editor. I tried using the "from/to" type of flange, but that merges the material together to create an impossible flat pattern.
Inventor 2021
JDMather
I'm getting lost trying to figure out which corner that is.
Can you back up a bit and indicate on the full part which corner that is?
Take a look at the Corner Seam option
boothdrafting
Wow that is going to make things easier
