Corner Seam creating strange extra bits
JoelRealEngineeringAU
Message 1 of 9
Hey there.
I've seen some poeple have a similiar issue, but either the fixes for them don't help here or their problem was slightly different.. I'm trying to put a corner seam between these 2 edges, and although the seam applies properly it leaves these strange little bits from the bend radius behind.. changing the bend transisitons / reliefs seems to do absolutely nothing (in both the default sheet metal settings, and in the corner seams settings). The two pieces that the seams are going between are seperate solids if it makes any difference. Any ideas?
Inventor 2022.1
Replies (8)
Message 2 of 9
bhavik4244
@JoelRealEngineeringAU
Does it shoes the same when you make flat pattern.
Could you attache the part?
Bhavik Suthar
Message 3 of 9
@bhavik4244
Thanks for your reply!
Yes, they appear even in the flat pattern.
I'll have to remove the detail from this model or build you another one that does the same thing. I'll get onto that now.
Message 4 of 9
CCarreiras
Try to DELETE the small faces with HEAL option on.
CCarreiras
Message 5 of 9
johnsonshiue
Hi! I have seen this behavior before. Usually it is geometry and relief type specific. Please share the file here. Forum experts can help take a look and propose a better workflow.
Many thanks!
Software Test Engineer
Message 6 of 9
@CCarreiras I can't seem to get into the heal / fix environment.. How do I go about this?
@johnsonshiueI've attached the files below.
Workflow suggestions would be awesome as this is a little slow.. Only because of all the fiddly stuff like corner seams.
Also a different way to do 'Face13' & 'Face17' wold be great, as I'm splitting this with sketches with GapSize because I need them to be seperate solids!
Thanks in advance!
Message 7 of 9
CCarreiras
Some things need a more "manually" edit...
Tip: You can also use the tool "direct" to do some direct edits...
CCarreiras
Message 8 of 9
johnsonshiue
Hi Joel,
Many thanks for sharing the files! I took a quick look. Sheet Metal commands may make assumption based on the local geometry and the given operation. It may lead to unneeded faces. I agree with Carlos. Based on the geometry and your modeling technique, it is better to use Delete Face -> Heal to clean up the faces and edges.
Thanks again!
Message 9 of 9
Thanks so much guys! That works exactly as intended!
