Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Corner seam creating cut instead of extrude
amir8JSY4
amir8JSY4
Hi everyone,
I am currently trying to make the corner seam , it show the preview (figure 1) but when i apply, it happen like this (refer figure 2). No flange are create and the part become cut instead of extrude. What do i do ?
Figure 1
Figure 2
Thank you in advance.
blandb
What version are you running? I just tested on 2024 and seems to work?
Please see attached
Autodesk Certified Professional
johnsonshiue
Hi! It seems like a bug to me. It should work as Brad's video shows. I recreated the Corner Seam on 2024.3.3. I could not reproduce it (see attached part).
If you know how to reproduce the behavior from scratch, please let us know.
In the meantime please install 2024.3.3 update.
Many thanks!
Software Test Engineer
amir8JSY4
Hi Johnson, I updated as per your suggestion and it worked ! Thank you for your help.
amir8JSY4
Apparently, i just need to update to the latest revision and it worked.
