Dear all,
I am working in an assembly i did not create myself. It is an installation assembly of a 46ft sailboat. Now it has this base component in it, in the form of an assembly where the user is able to copy objects like a surface or a solid outside of that installation component. The user can now use this surface to constain objects to it inside of the installation assembly. This used to work really well but now all of the sudden, somewhere in the process this went wrong and i get this message whenever i try to copy an object: "The associative option can not be enabled because not all necessary components can be made adaptive. Some components are allready adaptive in another assembly."
I understand all the words this error message gives me but i cant find the solution or the cause.
The base component has 7 surfaces and 4 workplanes in it.
I cannot upload the file here due to privacy reasons but can someone maybe guide me in the right direction?
i hope this is enough information for you guys to do your magic.
