Working in an idw file, I have a need for two drawing sheets with the identical views of the same part. However, each sheet will need different dimensions and annotations. What I would like to do is after completing one sheet, in one step create the second identical sheet, then just edit/add dimensions and annotations. Is there a method to do this? So far, I have only been able to copy one view at a time from sheet to sheet.
In 2013, you can multi select the views, then choose "Copy"..... change to the other sheet, right-click, and paste.
Done.
What version are you using?
