Copy Paste Weirdness ind IDWs
andrewdroth
Advisor Advisor
andrewdroth
You can't paste a copied item when a view is selected or if the cursor in off the sheet.
This is annoying, and it should matter where your cursor is or what you have selected, a CTRL+C operation should initiate a paste.
This is the closet Idea I could find relating to the issue.
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
johnsonshiue
Hi Andrew,
Indeed, the behavior is not reasonable. Ctrl+V should always be pasting if there is something to paste. I guess the clipboard was cleared after something is selected. I cannot explain the behavior. I will work with project team to understand the behavior better.
Many thanks!
Software Test Engineer
jhackney1972
The drawing view is an entity in Inventor.  If you hover over it and right click you will only receive view sensitive commands.  You can easily paste your weld symbol anywhere on the drawing sheet, except the view, and then place it on the view with an automatic snap.  As far as pasting anything outside the paper, this is not allowed by design.  Since everything outside of the paper border does not plot, there is little reason to paste anything there so it is not allowed.  You can drag entities outside the paper if you want if you want to keep it with the drawing but not be available to plot.
John Hackney, Retired
andrewdroth
I disagree.
I know that it won't show up in a plot, but if i'm hammering out a drawing set I should be able to set up the views wherever I want and then worry about their position on the paper space afterwards.
Welding symbols are only going to be placed on lines inside a view, so it makes sense that as soon as you hit CTRL+V everything becomes un-selected and the item in your clipboard is ready to be placed.
This is about efficiency and consistency when making drawings. Making drawings as fast as possible is the name of the game.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
mcgyvr
Seeing as how other software (Microsoft Word,etc...) allows what you are saying Inventor can't do then unless there is a very specific reason that this can't happen then I agree that it should fire right into the pasting command anytime even if you are outside the screen and/or have something selected already..
But this is about as low a priority issue as I could think of..
MechMachineMan
And on the 8th day, God created programming languages.
But seriously.... If you want efficiency and speed, customizing the tools using a programming language OR developing workflows and techniques that are compatible with EXISTING functionality will probably get you further than being at the mercy of another organization's schedule.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
andrewdroth
Word!
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
