Copy/paste section of sketch
I have part of a complicated sketch that I would like to duplicate and shrink down but I need both pieces.
B ---> B
I know I can make it a block and copy/paste but then I don't think I can edit them independently. Is there some way to do this?
Hopefully that makes a bit of sense if not I'll try to clarify more.
mdavis22569
make them a sketch symbol
and you can scale them independently, rotate  them etc
Mike Davis
Curtis_Waguespack
Hi jbrhx4,
  • Create the sketch block, give it a name, tell it that you love it, and will always protect it
  • Place another instance of the sketch block
  • Right click on instance 2 and choose Explode
  • Abuse the geometry that used to be instance 2 of the block, as you see fit
    • delete stuff
    • add stuff
    • make a new block out of it if you want
    • rotate and scale this new block
  • Observe that instance 1 of block 1 remains at peace
In the future, look for opportunities to create simple sketches:
http://inventortrenches.blogspot.com/2011/03/inventor-101-simple-fully-constrained.html
I hope this helps.
Curtis
Okay that allows me to edit it. But is there a way to scale the copied
block and shrink it down?
Okay how do you actually scale the block though?
Curtis_Waguespack
Hi jbrhx4,
I might have mislead you, by listing things in the order that I did. Actually, I just re-read what I wrote originally, and I just simply misstated it.  Smiley Embarassed
You'll want to create a new instance of the block, move it off to the side, explode it, then scale and rotate the loose geometry, and then create the new block, and then move/constrain it in place.
I hope this helps.
Curtis
