I am in the process of building up a standard library of assemblies/modules for substations and these assemblies have a lot of possible variance parts for similar applications. For our situation it seems like the only way to accurately show and have an intelligent BOM for each scenario is to create “one off” assemblies which will be virtually the same as the first “parent” assembly except for maybe a few parts and/or sub-assemblies.
A better example of this is, if the committee approves of a new structure and it is to supersede the dated one. I would like to be able to update that first “parent” assembly by replacing the old structure with the new one and for the “one off” assemblies to be linked back to the parent and update with only that structure. We have Vault set up and we could control what child assemblies are to be updated by managing the “WIP” or “Release” states for new revisions.
Right now with my understanding, it would be a manual process to update each assembly with the new structure because if I try to copy design the main assembly from Vault, it breaks the link afterwards. It would be highly inefficient because we are expected to have hundreds of variance assemblies and a manual process of updating them cannot be an option for us. I thought from the Vault, there might be a way to use the “Copy Design – Reuse” method, where one is to reuse everything except the top level assembly and to have everything in the new assembly be the same as the original model it was copied from and still remain “linked”.
I am very curious as to hear what some of your suggestions are. I have done quite some research around the web and these forums and I don’t think the several copy design tools within Inventor that are mentioned (Vault’s Copy Design Tool (Maybe?) , Inventor’s Copy Component Tool, Design Assistant, iLogic Design Copy Tool, iCopy, Pack n Go etc.) will cover what we would like to accomplish.
