Add quotes (") in the description of the elements.
How to do this?
Can someone help me?
Thanks!
Solved by jhackney1972. Go to Solution.
If I understand you request, add inch marks (") after the numbers, then you have the answer right in front of you. Notice how the "X" are being added between the leg lengths of the angle. Following suit, just add & """ at the position you want the quotes.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
