Copy constraints from one piece to another
Good Morning, Can you tell me if there is any way in an assembly, copy restrictions from one piece to another piece. The two pieces have the same restrictions.
Thanks.
COPE
JDMather
Is there any pattern?
Are you familiar with iMates?
NO, no hay ningun patron. Si conozco iMates; lo que me gustaria saber si cuando inserto una pieza en un ensamble, puedo copiarle las restricciones de otra pieza que esta en el ensamble.
NO, there is no pattern. If I know iMates; so I wonder if when I insert a part in an assembly, I can copy him restrictions other part that is in the assembly.
thanks.
blair
Unfortunately not,
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
