copy a single component with constraints to other components
Hello
I would like to copy a single component with constraints to other components in my assembly to the same location in the assembly and the same constraints. by "copy" I mean a "reuse" or a new instance of an existing component. but I would like keep all constraints to outside components. I didnt find an option for that. why?
I need  this because I need like 10 sliding objects on an axis. all have the same constraints relative to the rest of the world. and dont have any constraints relative to each other.
thanks you very much
niv
andrewiv
There is no way to copy a component and constraints without also copying the components that it is constrained to.  Can you show an example of what you are trying to do, there may be another way of accomplishing what you want.
Andrew In’t Veld
Designer / CAD Administrator
johnsonshiue
Hi! The closest thing in Inventor is iMate. But, you need to pre-define those iMates in each component. You cannot copy&paste constraints. Another workflow help facilitate constraining is called "Assemble." It is a quick way to assemble components in graphics window without having to recreate constraints individually.
Many thanks!
Software Test Engineer
prussellZXB3F
I've been chipping away at an addin that gives a copy with mates like experience. I'm about to ditch  what I've got and do a from scratch rewrite but thought I'd share the early beta as can still be a useful, although buggy tool.
screencast https://autode.sk/3ac5DGj
https://drive.google.com/drive/folders/1CI1ppMxqbDlYHlHe2pn8eRYhkG7AqWIK?usp=sharing
drop the .dll and .addin into C:\ProgramData\Autodesk\Inventor Addins
Regards Phil
ethanfL67BY
Hello Phil,
Do you have an updated addin for this?
ssharpe2GXW3
Still 15 years behind Solidworks... Bravo Autodesk !
amol_swami
Community Visitor
Community Visitor
In another software we have a option when we copy it it asks for constraints where & which constraints you want to replace or add its where easy in it. Same should also have a option in it.
