Cool Orange Thread modeler only working one one side
leowarren34
Mentor Mentor
leowarren34
So I am working on an axel for a design piece and on each end I need a thread,I split the bar at each end to make a 10mm long thread, when I use the thread modeler only one side works the other side doesn't, any help or work around would be appreciated. Left side is what I want...
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Accepted solutions (4)
Mark.Lancaster
@leowarren34
Why would you need to split at all?  You can just indicate the length of the thread in the thread function.   Can you share you part file?
Mark Lancaster
Cadmanto
Yeah, I am with Mark, why would you split.  Why not just create the rod and add a thread on each end.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
mcgyvr
can you post your ipt file?
It might be a minor bug in the coolorange tool.. You would need to contact them for support about why its not working..
As to not needing to split you can simply uncheck the "full length" option in the thread dialog to avoid needing to split for each thread..
johnsonshiue
Hi! The behavior does not look right to me. I will let coolOrange team know, so somebody can take a look.
Many thanks!
Software Test Engineer
leowarren34
Didn't notice the full length box, thanks for the tip, just testes and works when you don't split but still this behaviour is unusual
Leo Warren
leowarren34
Problem solved, thanks just overlooked it
Leo Warren
