Converting IDW to autocad DWG using task scheduler
Dkaliksis
Dkaliksis
Community Visitor
Community Visitor
Hello.
I have been trying to convert a folder full of IDW's to autocad DWG's using the task scheduler. The client will not accept inventor DWG's so it needs to be autocad. Currently I am doing this by doing a create task -> export, file type DWG.
This only converts the files to inventor dwg's though. Is there any way I can create autocad DWG's instead?
Gabriel_Watson
Use the "Export as" option instead, and pick the DWG extension as your type of input, then select which drawings you need to convert. You can click on the "..." button at the "Output File Name" cells later to confirm you will be saving in AutoCAD DWG format.
