Converting database of stp files to jpeg with isometric drawing view
I've been given the task to transfer a large database of STP files to a jpeg/png/pdf of isometric view as normaly seen in drawing mode.
How could I automate this so I wouldn't need to manually open - transfer to drawing - place view - export?
Is there anything built in to Inventor or any other softwave that could help fixing this or save me some time?
Would appriciate your help!
mdavis22569
Yes ....
You can probably do it 2 ways   ...
Task Scheduler, 2 parter:  1) Translate/save 2) Save as ...whatever you want. You would pick the files or folder
Ilogic: code it and do all of the above in 1 step...but you would have to do it 1 file at a time
The only issue I see is how the iso looks. It might come in diifferent from what you want ..
Mike Davis
Curtis_Waguespack
Hi niklas.danielsson,
What version of Inventor are you using?
Do you want to save the files as *.ipt files also, or just output the *.jpg files?
I hope this helps.
Curtis
I am using Inventor 2017. I also have the possibility to use 2014 if that would change anything.
The output only needs to be in a image or vector format only.
Curtis_Waguespack
Give the attached file (created with Inventor 2015) a try. It has a batch process iLogic tool I created that allows you to select multiple files, and it contains a rule called "Set_JPEG_Thumbnail ***"  to create a *.jpg file from the selected list of files.
Note that the iLogic rule called "Set_JPEG_Thumbnail ***" has a line at the top that reads:
oFolderPath = "C:\TEMP\JPGs"
Just change that to any path you want, or use that path and it will create that folder, and then you can move the image files afterward.
Note that the *.jpg is not from "drawing mode" though.
I hope this helps.
Curtis
