Converting Composite STEP File to Solid Format
msohaibPLAF8
msohaibPLAF8
Greetings,
I'm currently working on integrating a STEP file of a rigid stand from Thorlabs into my assembly. However, I've encountered a challenge – the STEP file is in a composite format, which prevents me from directly including it in my assembly.
I'm reaching out to inquire if there's a method to convert this composite STEP file into a solid format that I can seamlessly incorporate into my assembly. Here's the link to the file for your reference: [link].
Any guidance on resolving this matter would be greatly appreciated.
Thank you for your assistance.
Best regards,
Mohammad Sohaib
CCarreiras
Hi!
Your part is full of surface "errors":
After fixing, here you have the part:
File attached, V23
CCarreiras
msohaibPLAF8
Thanks a lot for your generous help!
