Converting a database of fabrications to Inventor
Hi All,
I'm coming over from autocad, so I apologize in advance if I get any of the terminology mixed up.
I'm working with an existing database of member fabrication data to migrate the data into 3d models. All the parts in the database can be treated as an extruded profile (tube, channel, angle, etc...) which is then fabricated (Holes, Notches, Cuts, etc...). See below for an example of some of the kind of parts I'm dealing with.
I'm exploring using iParts to quickly generate the models for these members but I'm running into an issue for how to handle the possible variation in quantity of fabrications. I could have anywhere from 0 to n holes on a given part, each with an independent location and size.
I've considered setting up a template sketch to define the hole location, but then a unique sketch/feature is required for each additional hole which is more setup that desireable & runs the risk of not being enough for some of our consolidated fabrications.
Is there someway to dynamically clone and modify a part feature with independent parameters using iLogic, or is there another better solution?
Any advice would be appreciated.
