I'm wondering if there is an easy way to convert this standard Inventor 2015 part to a sheet metal part so I can create a flat pattern. I've had some light sheet metal training years ago, mostly unused and forgotten. The part was created from a thickened surface quilt in a multibody solid. I'm recreating a complex assembly from 2D drawings from the 70's and many of the dimensions are implicit and derived from other parts in the assembly. So it was just easier for me to model by this method.
This isn't necessarily an urgent problem, as the original drawing didn't provide a flat pattern, so I wouldn't be doing any worse if I simply detailed the part as a standard solid model, but it'd be nice to know for my own record. I tried adjusting the thickness in the sheet metal standards and filleting the corners in such a way as to maintain uniform thickness, without any luck. I hadn't played with the K-factor at all.
