I'm new at this so I need major help with the smae complication. I don't understand!!!
I need you to be more specific. Do I have to make a totally new part?
Attach your file here.
Let's see what you already have.
It's an Iphone 5 C stand amplifier
Every time you entered a dimension value - Inventor told you it was using inch units.
To correct the part
Start a new Metric (mm) part.
Go to Manage tab> Derive
Select your original part file and enter scale factor
Next time pay attention to Units.
To correct the part
Hi! Kyle,
There are a few options depending on the model you have. For this particular case, I personally think you would be better off do the following.
1) Go to Tools -> Document Settings -> Unit -> change it from inch to mm. This will make all the model parameters in mm unit but the actual values are changed.
2) Edit each feature from top to bottom and change the parameter value from inch-base to mm based (simply replace "in" with "mm).
In this way, the model will be properly rescaled and all parameters are converted accordingly. In 2016, you can use Direct Edit -> Scale -> Uniform -> 1/25.4. In 2015 or earlier, you will have to use Derive -> Scale like JD mentioned here.
It looks like you might have picked the wrong unit template to start with. You might want to either pick the unit-specific template next time or go to Tools -> Application Options -> File -> Configure Default Template to reset your default template to mm-based.
Thanks!
Hi! Kyle,
Thanks!
Nevermind. We're going to print it with our 3d printer soon, so I'm going to make it again using the same dimentions with the firstone and make it again in mm.
Thank you so much! I will try that once I get to that class. Thank you for your help!!!!!!
How do you change it without changing the values of the parameters?
Hi! I still think change the parameter unit is the right way to do this, especially if you want to use the file in the future. The other options you have would be deriving the part as a new part and set scale factor to 1/25.4 (Inventor 2015 or earlier). Or, you can use Direct Edit -> Scale on Inventor 2016.
Thanks!
Thanks!
