Is there a way to convert a linked drawing view of a part into a dumb unlinked sketch?
This is a simple feature in Solid Edge and ProE, but I can't figure it out in Inventor.
In my case, I want to create a 2D schematic (a sketch) on an assembly drawing sheet.
In Solid Edge and ProE, I could create a view of a wire nut, right click it and select "Convert to 2D", or something similar.
The view would then become a dumb unlinked sketch, that I could copy and paste numerous times to create my schematic.
The only way I see to do this in Inventor is to create multiple drawing views of the wire nut.
If the wire nut model changes, my drawing will change.
Also, it would be nice to have the entire schematic in a single sketch feature, so I could copy and paste that to other sheets to make variations.
Thank you for your help!
